205 CTI 1.6
christaylor689@gmail.com
By christaylor689@gmail.com, 06/27/2019
  • 1,634 views
  • Color Red
  • Year 1990
  • Short Description Hello a short description you must be joking you must excuse my lack of secretarial skills i've owned this CTI For three years its 1 owner only 67000 miles full history with a wallet full of invoices with i've added to . Its always been kept in the garage and worked on weekends apart from stone chipps faded paintwork which have been corrected it didn't need much i've done the usual cambelt and water pump the catch tank at the back of the block the steel tube on the bottom hose cleaned out all the air hoses so it ticks over properly replaced the coil amp the list is endless these also suffer from electrics on the inlet manifold it won't allow it to rev past 4000 rpm again rectified i've probably been through every nightmare from not ticking over properly to won't rev properly and i'm happy to say this one FLYS the sound of the induction is amazing anyway i've probably missed loads its oil pressure is over 3/4 on cold at tickover ect i'm only selling because of other projects .
  • Car Type / Usage Road car
  • Engine & Gearbox Standard
  • Brakes Standard
  • Wheels & Tyres Standard
  • Interior & ICE Standard
  • Comments & Plans None
