By Andy,
10/07/2016
- 3,324 views
- Color White
- Year 1992
- Short Description Started life at a Graphite 1.9 gti. Now in the process of becoming a white Mi16 via a complete strip to bare shell . It would be nice to be able to drive it again by next summer!
1.9 mi16 fully rebuilt with new liners, full balance . Head has Petert solid lifters cams and engine is managed via a K6 emerald, Jenvey bodies and wasted spark.
Gearbox is a full rebuild with new synchromesh hubs . Ratios are 1.9 gti 1-4, 1.6 gti final drive and 5th is 6th gear from a gti6 box, all finished off with a 225 mm Mi16 push clutch -
Standard rebuilt rear beam with Gaz dampers and lowered ( 20mm) ride height
Front is Gaz coilovers . Experimenting with spring rates but starting with 10" 140lb springs
Steering is power rack and Saxo electric power steering pump mounted on the battery tray. Battery is in the boot - Brakes Standard rear but with AP adjustable bias valve. Fronts are 283mm discs on bells and 6 pot calliper from Pug1off
Wheels & Tyres
speedline SL434 with Toyo Proxy tyres
Bodywork & Exterior
Standard except for aftermarket reclining front seats
All brake lies are braided and fuel lines ditto. - Interior & ICE Standard
- Comments & Plans Now on the road and going well. Need to fit some rear mud flaps . No immediate plans as I am building a similar engine for a friend, so busy at the moment
