Copier Doctor
By Copier Doctor, 04/22/2014
  • 2,337 views
  • Color Black
  • Year 1989
  • Short Description --
  • Engine & Gearbox 1.9 XU9 engine, Catcams camshaft, 11:1 CR, Weber DCOE carbs, XU10 oil pump spring. 4-1 SS manifold and SS exhaust system. 1.6 GTI gearbox, 1.6 flywheel, bronze linkage bushes, Group N linkages, Griffiths Eng short shift kit.
  • Suspension & Steering Front suspension is Avo height/rebound adjustable coil overs with KAD eccentric top mounts currently on 190lb springs. 309 GTI arms, with new OE bushes. Upper and lower Sparco strut braces.
    Rear suspension is Avo rebound adjustable dampers with 21mm torsion bars and a 24mm ARB. Solid mounts.
  • Brakes Brake hoses have been replaced with Goodridge braided. Rear hoses routed internally through an AP Racing bias valve. discs all round. Rear is 1.9 disc set up. Girling front callipers with Mintex M1155 pads.
  • Wheels & Tyres genuine Speedlines with Toyo R888 tyres
  • Interior & ICE Safety Devices C12 roll cage with door bars and extra rear harness bar.
    Modified tunnel to mount seats to welded tubes from tunnel to sill.
    Sunroof plated with polycarbonate windows.
    Interior is Sparco Rev seats (floor mounted) with TRS 3" 6 point harnesses. Helmet net. Removable steering wheel.
  • Comments & Plans None
