kirkas4
By kirkas4, 07/25/2013
  • 3,313 views
  • Color Black
  • Year 1988
  • Short Description Quick
  • Engine & Gearbox ENGINE
    Mi16 1927cc (stripped, tolerance checked, Chemically cleaned and rebuilt)
    83.5mm IAPEL Forged Pistons
    83.5mm IAPEL liners
    Catcams Forged Conrods
    Catcams Forged conrod bolts
    Catcams 528 inlet/exhaust camshafts
    Catcams Vernier Pulleys
    Balanced crank, rods, pistons & flywheel
    Spesso triple layer Kevlar head gasket
    Mangoletsi inlet manifold
    Longmans 4 branch exhaust manifold: Ceramic coated
    Twin 45 Dellorto Carburetors
    OMEX Ignition Management
    Magnicor 8mm ignition leads
    Lumenition Air / fuel ratio meter
    Full Rolling Road Setup
    XU10J4 26T oil pump sprocket and 52 link chain
    DES Aluminium Direct Cold Air Feed to carbs
    Samco water hoses
    Baker BM Group N engine mounts
    Heavy Duty Bottom Engine Mount
    Powder Coated Rocker Cover
    Lower Radiator Using Custom Aluminium Bracket
    DES Aluminium Oil Catch Tank & Breather
    DES Baffled Oil Sump
    Steel Braided Fuel Hoses
    Silkoline Pro R 15w-50 Engine Oil
    Exhaust: Custom DES Stainless Steel system
    Carbon Kevlar bonnet
    TRANSMISSION
    Re-built 1.6 GTI Gearbox
    Quaife ATB Limited Slip Differential
    Silkoline SYN5 75w-90 Gear oil
    Quick-shift gear linkage
    Mi16 Clutch
    Lightened Flywheel
    Quaife 2.4 turns Quick Rack
  • Suspension & Steering SUSPENSION
    309 GTI Wishbones & Driveshafts
    309 GTI front ARB
    Gaz GGA Gold front Coilovers, 275lb springs, 2 degrees negative camber
    Baker BM Eccentric Top Mounts
    Sparco upper strut brace
    21mm rear ARB
    23mm Torsion Bars
    Gaz GGA Gold Adjustable rear dampers
    Group A Solid rear beam mounts
    Skip Brown rear negative camber kit
    Polyurethane suspension bushes
  • Brakes BRAKES
    306 GTI-6 Calipers
    Standard vented discs
    406 23.8mm master cylinder
    Wilwood EXP 600+ Brake Fluid (High temp racing brake fluid)
    Wilwood Brake bias valve with internal brake lines
    Ferodo DS2500 Brake Pads (Front)
    Ferodo DS3000 Brake Pads (Rear)
    Steel braided hoses
  • Wheels & Tyres Dry - Silverstone Semi Slicks
    Medium - R888
    Wets - R1R
  • Interior & ICE INTERIOR
    Safety Devices six point roll cage
    Stripped out interior, dash, heater, spare wiring
    FIA Cut off switch
    Lightweight Cobra Imola Seats
    Lightweight 6 point Sabelt harnesses
    Life Line fire extinguisher
    Momo Steering wheel
    Polycarbonate windows
    Racetech Oil pressure gauge & Volt meter
    Oil pressure warning light
  • Comments & Plans Fiber Glass Boot
    Light Weight Starter
    Light Weight Alternator
    Big Big Brakes
