205jsy
By 205jsy, 06/17/2013
  • 2,647 views
  • Color Porsche Riviera Blue
  • Year 1987
  • Short Description --
  • Car Type / Usage Race / Rally car
  • Engine & Gearbox o Longman Group A head with Piper 285 cam, vernier pulley, 43mm inlet /
    34.5mm Exhaust valves. Bronze guides. All CCs balanced to give 10.6:1 CR.
    o Balanced bottom end
    o ARP Rod bolts
    o PTS Baffled sump.
    o K&N Filter
    o Ceremetallic Paddle Clutch
    • Longman Exhaust Manifold
    • Powerflow Stainless Steel exhaust system
    • Motronic Mappable ECU
    • “Nissens” Alloy Radiator
    • Pacet Electric fan.
    • BE3 Gearbox with PTS gearkit.
    • Tran-X plated LSD with 45/45 & 30/45 degree, ramp plates.
    • 4.8 Crownwheel & Pinion
  • Suspension & Steering • Upgraded power steering system & hoses.
    • Bilstein 2¼ Adjustable front struts
    • 309 Front anti rollbar
    • PTS Rose jointed bottom arms
    • 1.9 Front hubs
    • 309 1.9 GKN driveshaft’s
    • Bilstein rear shocks
    • 309 rear beam, with 306 rear arms.
  • Brakes • 1.9 Rear discs & callipers with Mintex 1144 pads.
    • Big brakes on the front – (Dia 285 x 26), 206 GTi 180 (Brembo) discs, callipers & Ferodo DS3000 pads.
    • Bias pedal box with dash adjuster & strengthened bulkhead.
    • Vertical hydraulic handbrake.
    • Alloy handbrake.
  • Wheels & Tyres (Hankook Z209 & Kumho C03 moulded slicks various compounds).
    8 x Yokohama tarmac tyres
    20 x Powder coated 1.9 Gti Alloy wheels
  • Bodywork & Exterior Msa 4mm Mudflaps.
  • Interior & ICE • Suede dash
    • Carbon door cards + various other carbon parts
    • Cage mounted professional camera mount
    • Dash mounted oil light
    • Omex rev limiter & shift light
    • Dash mounted fuse box
    • Cage mounted map reading light
    • Aux. lighting switches & relays
    • Sparco seats
    • Sabelt 6 x point harnesses with 3” shoulder & 2” lap & crutch straps.
    • Welded in seat mounting tubes
    • Sparco alloy side mounts
    • OMP Suede steering wheel
    • Brantz trip meter
    • Large display digital clock (Mayes Motorsport)
    • Large capacity plumbed in & handheld fire extinguishers (International spec)
    • Alloy floor plates (Driver & Co-driver)
    • Alloy Co-drivers footrest
    • Sparco helmet box
    • Peltor intercom
    • Sparco ratchet wheel tiedown in boot
    • Aeroquip Fuel & brake lines inside the car.
  • Comments & Plans Stronger driveshafts, maybe try a quaife differential, re spray underneath of car, refurbish rear beam, try making the car lighter.
