By stig3131,
04/13/2013
- 3,079 views
- Color red
- Year 1986
- Short Description phase 1 205 gti road rally spec. bulit to be reilable and fun
- Car Type / Usage Race / Rally car
- Engine & Gearbox engine pretty much standard bar the induction kit power boost valve, uprated engine mounts bbm, samco hose kit, alloy rad, electric fan, fuel sampling valve msa, battery in boot, Gear box BE3 has 4:4 cwp with 4 blade paddle clutch and quick shift rose joint linkages.
- Suspension & Steering bilstein fixed platform front struts with challenge springs, comp brake fixed strut tops, rear bilstein shocks on solid mounted beam. 205 power steering, up rated arb bushes
- Brakes groved and cross drilled front with mintex 1144 material pads goodridge hoses. rear goodridge hoses and standard discs oads (mintex) hydralic handbrake with fly off conversion
- Wheels & Tyres various mix 14" and 15"
- Bodywork & Exterior auto bonnet, window film for msa, tow straps, 4mm mudflaps msa, wide sumpgard, alloy tank guards,fuel neck guard,
- Interior & ICE omp cage, omp seats on welded in seat rails and sparco subframes,omp suede wheel, trs 3" harnesses, navigation potti, navigation led light
- Comments & Plans msa log book, bigger brakes,
