309 GTI 1.6
By allanallen,
03/07/2013
- 2,915 views
- Color White
- Year 1988
- Short Description It's a phase 1 309 xs!
- Car Type / Usage Trackday car
Standard Xu10j4rs, 16 row oil cooler, custom twin box centre run/exit stainless exhaust, baker mounts, butchered engine mount with custom mounted alternator. Lynx bottom pulley, walbro 255 fuel pump, blanked resonator, vac pump and t body heater, vac pump, 'flipped' fuel rail.
1600 be3 gearbox with gripper plated LSD, mi16 Valeo clutch, rose jointed gear linkages, bronze bushed pivots -
Gaz golds with 500lb 6" springs
25mm tbs, 28mm arb
21mm front arb
Bridgecraft neg camber hubs
Bridgecraft neg camber tailing arms
Bridgecraft roll centre correction kit
Bridgecraft bumpsteer correction kit
Raldes spherical bearing top mounts
Custom beam mounts
3.2 pas rack, 106 electric pump
Seam welded subframe
Pony strut brace
Brakes
Front Hi spec R114 calipers custom mounted on 266 206/306 brembo disks, m1155 pads
Rear standard calipers, oe pug pads, brembo disks
Gingerspeed bias pedal box
Braided lines throughout - Wheels & Tyres All standard 1.9 wheels with r888s, Michelin slicks or wets
Bodywork & Exterior
Gti trims, bumpers with blanked fogs, glass, phase 2 grill
Xs and phase 2 gti spoiler
Lightened bonnet, doors, boot lid, bumpers, mounts etc etc
Poly door windows
Roof vent
Bit of light weight racing rust -
Interior & ICE
Weld in roll cage, double door bars, dash bar, harness bars etc
Chopped tunnel and seat bars
Motordrive buckets and willans 3" harnesses
No dash, small ally centre console, electric demisters
Lowered steering column and dished suede wheel
6 gallon 'sumped' fabricated fuel tank sunk into rear seat well
Battery sunk into boot floor
Beaded seat cover - Comments & Plans Future plans- Mi16, better brakes, lower,lighter,box in the fuel tank to meet msa regs.
