205 GTI-6 2.0
baz205gti
By baz205gti, 01/19/2013
  • 2,888 views
  • Color Cherry Red
  • Year 1987
  • Short Description Track muted pug, standard gti6 lump, looking to lighten more and spread weight out evenly around the car,
  • Engine & Gearbox 306 GTI6 engine
    VTS/XSI 2.0L 5 Speed box
    Custom short throw linkage, clutch cable
    Braided teflon fuel lines inside
  • Suspension & Steering Spax Coil overs, 309 lower arms, modified sub frame, 1.9 running gear
    rebuilt 1.9 rear beam
    Lowered and reangled steering column
  • Brakes Wilwood 4 Pots, 1.9 spec rears
    Copper brake lines inside car
    Bias Valve
  • Wheels & Tyres Compomotive TH ex Ford Motorsport wheels
    406 Steels
    Xsara Steels
  • Bodywork & Exterior Pretty much original body less the rust custom grill and crossmember tp clear gti6 inlet, soon to be louvered bonnet
  • Interior & ICE 2.0L GTI6 theme tune grrrrrrrrrrrrrrrr
    Stripped interior, 10 point OMP cage, buckets etc
    Grafted a auto gauges rev counter with shift light into original dash.
    Battery, wheel mored to boot floor.
  • Comments & Plans bit of winter tinkering ....... now back on the road ready for spring erm spring where are you its easter!!!!!!
