By DRTDVL,
12/17/2012
- 3,343 views
- Country New Zealand
- Color Gray
- Year 1988
- Short Description Life started as a 1.6 gti press car, it was eventually converted to a 1.9 Mi16 racecar... it's soo much fun...
- Car Type / Usage Race / Rally car
Engine:
- Oil Cooler = 11 Row external (i think it's 11 row) Mocal
- Engine = 405 MI16 4WD XU9J4
- ECU = 405 MI16 4WD XU9J4 + Peter T Chip
- Engine Mounts: BakerBM Top mount, Custom Uprated Lower Mount, BakerBM gearbox mount, BakerBM Group A lower rear bush
- Sump = Customized Sump (Windage Tray, Increased Volume, Trapdoor baffles)
- Fuel Lines = moved into cabin, all braided lines
- Oil Breather System = Custom
- 6-Bar PTS Oil Pump Spring
- Custom Heat Shield
- Washer bottle = 309 rear bottle
Exhaust:
- Custom 2.5 inch system, painted with Black High Temp paint
- Factory Manifold
Gearbox:
- Kevlar Clutch (i think)
- 306 S16 Be3
- Quaife ATB Diff
- Upgraded linkages
- Custom Quickshifter
- Phosphor Bronze bushes -
Front:
- Camber / Caster adjustable top hats
- Billie Coilovers
- Seam Welded front subframe
Rear:
- 22mm Torsion Bars
- 306 Road Billies
- 25 mm and 24mm ARB's
Brakes
Front:
- 307 Calipers and discs with RC6 pads
- Braided lines
- Peugeot 406 23.8mm Master Cylinder
Middle:
- Adjustable bias valve
- Hydro Handbrake
Rear:
- 1.6 GTI front pistons attached to the rear pad carriers - standard fast road pads
- Braided Lines -
Wheels & Tyres
Wheels:
4 x ROH Astrons (15 x 6.5)
4 x 306 S16 rims
2 x 205 GTI “Speedlines”
Tyres:
- Dunlop semi-slicks -
Bodywork & Exterior
- Painted Unknown Silver Color
- Satin Black painted trim, door handles, wing mirrors, slam panel, skuttle plate, gti badges
- E30 Pre-Facelift lower lip – modified to fit
- 206 GTI rear wing – modified to fit
- Sump Guard
- Clear front indicators
- 405 arms wiper and 306 blades (larger sweep area)
- 205 “Automatic” Bonnet
- Spotlights cut out of Bumper, with custom blanking covers
- Rear 1/4 windows = Lexan
- Sideskirts have had jack mounts fabricated into them
- 3M High Temp Foil Tape along trans-tunnel
- 88 GTI wing mirrors (smoother and smaller then later gti mirrors) -
Interior & ICE
Interior:
- Battery behind co-driver’s seat
- Water Temp, Oil Temp, Oil Pressure gauges
- Electric Kill Switch
- Interior Panels replaced with Carbon Fibre Panels
- Chrome-Molly Roll Cage
- Interior Completely stripped bar Roof Liner
- Dash modified to fit rollcage
- Seats = Racetech 4009w (D) & Racetech 4000 (P)
- Belts = Racetech (TRS) 3inch 6-point
- Steering Wheel = Momo Race
- Flooring = Checker Plate, sound deadening removed
- Terraphone Professional Amplifier + 2 x touring head sets
- Custom Extended Steering Wheel Shaft -
Comments & Plans
A CRAP LOAD!
- Aftermarket ECU
- New cams
- ITB's
- Poly/lexan windows all-round
- lots more...
