Andy F
Hi people
Can people with experience of the XU block take a look at a couple of pics of my block.
The block seems very pitted guess its where its been attacked by the anti freeze. I guess its nothing to worry about?? Also everything in the block seems very heavily stained by the oil. I wondered if someone could tell me the best way to clean it up as have tried degreaser with parafin and doesnt seem to shift unless i use the wire brush on it.
Thanks for the help
jimistdt
There is a few suggestions in here Andy
Petrol/Diesel/Wheel Cleaner seems to be the way forward!
More like the lack of anti freeze, its a corrosion inhibitor too.
As above, The deck of the block by the W/P area looks pretty bad so worth checking as if the seals not right water can leak past
Cameron
Make sure you clean the rust and crap out of the liner seal surfaces before you put it back together.
I cleaned mine with lots of hot water and Jizer.
Andy F
i was going to give it a test with the liners etc in to check water doesnt pass as the rusty crap was pretty much what was holding the old ones in.
would you think it worth putting the effort into this block or look for another one as there's a few about??
Guest looney205dudey
the best thing to clean the block out is some alloy wheel acid but make sure you have a hose handy to wash it out again. and with like a toothbrush or something a lil bigger just give it a scrub round and that should clear it all out for you :rolleyes:
i did it on a 468 big block chevy block and it did the trick :)
