shalmaneser
Nice Quick Exhaust Question
shalmaneser
As described, just a quicky.
Got some new downpipe/manifold bolts and flexi joint from the bay of dreams.
just wanted to confirm where the fibre/asbestos looking washer goes, it's one of the two options below. So can i get an answer - top or bottom.
Cheers!
bensonmi
the ones on the bottom,or if you cant get the nut on,fling them!! ;)
johny105_y2k
i reserve the right to be wrong but it looks as though the washer fits inside the little top hat washer.
so in answer to you rquestion the top one
johny
jplautomotive
no
bottem pic
jonny
it should go in the cup, or at least that's how every one I've removed and fitted has been!
Edited by welshpug
bensonmi
sorry i read the question wrong,the bottom of the bolt i mean, which is the top pic!
Rom
Ive always fitted mine like the top pic !!
shalmaneser
yey, thought it would be the top pic - with the washer in the cup. That's what it looked like under the bonnet but the washer has crumbled away so i thought it best to check!
Thanks everyone!
Cameron
Top pic. I think its supposed to insulate the nut or something. ;)
jplautomotive
no bottom pic between spring and downpipe flange NOT IN CUP , its to stop the spring squeaking on the exhaust
Edited by jplautomotive
dcc
The kit i last bought didnt even have that washer in there, i also lost the little cup thing on one side, which was replaced with a big washer i think. getting a new exhaust when ready so not really bothered!
Exactly!! The squeaking is damn annoying!
shalmaneser
Good knowledge! that settles it....
strange, what's this squeaking you speak of?!
Particularly when the engine mounts are worn it allows the exhaust to move, has to hinge/flex somewhere and that is where, hence the ring mesh/fibre gasket thingy is supposed to allow a bit of movement, but they squeak a bit if the washer isn't on the springs as above... :)
Cameron
Ohh welly well.. you learn something new every day don't you. :rolleyes:
I'll have to go and swap mine around now. Doh..
hexhamstu
i think i also fitted mine in the cup, nightmare. i hate those bolts! so hard to reach both ends.
trialster
mines in the 'wrong' way round, but it aint bloomin' coming back off again thats for sure :)
