Finding Tdc
Stu
Ahh... Now i fully understand your PM ;)
Question is; can this be done in situ? i.e. the marker bolted up?
Yes. Just be careful not to drop anything down the hole!
ORB
Whats the story if you have an Alloy block MI16 engine with a GTi Flywheel?
Are the timing marks the same (teeth position?)
Yes.
ORB
cool, thanks mate
Nice article Peter, that makes TDC so much easier that messing with a DTi etc like I did when I timed the cam on my 8v.
I take it this method would work just the same on an 8v with an Mi or similar 60-2 flywheel fitted?
Stu
Question is; does anyone have the part numbers for said items.. ;)
yeah, peugeot does ;)
not listed by peugeot at all, though it does appear in a picture, the part number no longer is.
I did however find the part number on Miamistu's copy, I think this is pretty old as there have been several occasions I couldn't find a part number in Peugeot's records only for it to be on there.
0329 35
