davepug205
Engine Stand
davepug205
Hi everyone,
What are your thoughts on a 350kg engine stand holding a built up XU? As theres quite a difference in price when you go for a heavy duty one.
Cheers Dave
well an alloy XU built up is 100 odd kilos, an iron one 160 odd from memory, so a 350 kilo stand will be more than strong enough
davepug205
Cheers Welshpug I didnt know if they would be cheap and flimsy,as theres alot of 550kg ones about :blush:
Dave
Edited by davepug205
philfingers
I got mine from http://www.jawel.co.uk/specialoffers.htm (it's the 1000lb one under lifting equipment) and it's fine for £25. Had an Mi alloy block on it and it's perfect. I think as it's 4 castor one it's more stable than a 3 castor one
matty_gti
Ive been using a 350 odd kilo one from machine mart with no problems and that had my TT engine on it for a while. :)
Mine's a cheap sealey one and holds a heavy Cosworth BOA V6 fine.
