Guest Pingo
How Do I Connect The Fog Lights?
Guest Pingo
Hi.
I am installing fog lights on my 205 gti and need a little help to find out which cable I shall connect the lights to.
I can see a red plug cable on the right side near the battery. Is this the correct plug?
Thanks in advance.
Rom
If memory serves me right. The fog lights plug into squareish Yellow connector, 2 pin, quite big. There is one either side by the headlights.
I think the red plug your on about is in the same sort of place, but i think its something to do with the wiring for twin fans (Diesels)
If yu have the Fog lights, you should be able to just match the plug up that way. Theres about 10" or so of wire on the light end.
Edited by Rom
Guest Pingo
I have now mounted the lights and thy work great. Thanks!
