timmsy19
Citroen Xantia Fan Blower
timmsy19
hi all.
First off iknow this has nothing to do with a 205 so if this is in the wrong section please move.
Right well my mum has been having issues with the heater blower on her car, ive checked power from the ignition and its working perfectly. now ive also checked the connection under the glovebox but the power dosnt seem to be getting that far.
Anyone have any ideas where i should be looking?
there's no relay, fed from F20, via a speed control unit, a resistor unit, and the Motor, at least that's what the Haynes manual says :D
There;s a relay for this on the 306, Not quite the same car I know but close enough, Just pull the relays out of the fuse box and check them for sign's of heat
Its usually the slider control that dies on Xantias, I've changed loads over the years. There are two different parts, ac and non-ac so make sure you get the right one if it is this.
