Kennyb
Size Of Pin Between Clutch Arm And Lever
Kennyb
Ok after my clutch cable just snapped i've lost the piece of metal that sits in the little diverts between the clutch arm and release lever !!! silly design really as this is the third i've lost in all my 205's.......usually i make a spare to the same size but cant find my spare...
Could anyone tell me the size of it so I can cut another from a bolt? .....cheers
Cain
ifcho
if there was a top of the silly design things in the 205, ,i think this would be the leader !
dcc
I'll have a quick look, but I think I may have one of these in my key box , had to buy 5 from pug a year or so ago, if I do, its yours gratis!
Saveit
Could someone measure the length? Cause i have the same problem.
Phil H
then add a spring between the two parts to hold it together.
Saveit
No length?
states the approximate size in the thread I linked...
dcc
found 3 of the 5 i bought.
If you want 1, send your Address in a pm to me.
Saveit
dcc; you wouldnt like to send one to Denmark wouldnt you :rolleyes:?
dcc
yeah, no worry. pop me your address
chris-gti
Those bloody things are the pinnacle of all stupidity, i drilled mine and put a bit of wire through it and round one of the lugs on the gearbox so if it does drop out again after a clutch cable goes, it dosn't fall down the nearest manhole.
Will measure up for you tomorrow when I find it in the daylight if you still need the measurements.
philfingers
41.2 x 8.0mm
I drilled a 2mm hole in the middle of mine and it's now lockwired to the box so if it falls out it doesn't go very far!
Phil
