chris 417 mi
Not A 205 Xu10j4r But A 405 Xu10j4r......
chris 417 mi
Just a quick question with my current project, engine is pretty much in & all plumbed up but i have a slight problem with 1 or 2 hoses and parts :
hose with what looks like a vapour pipe to the charcoal canister in the wing ... where does this pipe up too now ?
main water hoses (thermostat housing to rad ) the one in the middle is the original 405 hose which fits the rad fine ...but doesnt mate up to the stat housing very well, the one on the right is a 406 hose which fits the thermo housing perfectly but doesnt mate up to the rad. Options ive considered are either joining the ends of the two with a pipe in the middle ...or removing one of the ends and fitting it to the other pipe if this is possible.
another shot of the bay
and the car it is in ...which started out as a 2.0 8v auto :wacko:
Isnt it an RS not an R? :wacko:
the charcoal canister pipe goes to the small port on the black plastic part on the front side of the throttle body, the pipe with the round inline valve goes to larger port and connects to the rocker cover
wondered when someone would finally do one of these, have you stuck with the 6 speed box?
an alloy joiner sounds your best bet to join the top hoses together, it'll be far cheaper than a thermostat housing adapter.
do I spy a BRAND NEW bumper on top of the car???
chris 417 mi
lol it started out as an r :wacko: gti6 inlet & exhaust mani & cams later and ...well :P
Nah as it was a xu10j4r it only had the 406 box on , now has 1900 be3 :)
  Quote
dont suppose you have a pic ?
  Quote
Yup indeed it is and genuine too :P a place near me can get bits fairly cheap, that was £80.
bang in the middle of your first picture, the port points towards the offside and is about 3-4mm in diameter IIRC, its below the one that points skywards for the breather pipe.
chris 417 mi
  Quote
excellent cheers :wacko:
hexhamstu
will you come and live with me, just so when ever i have a question you can instantly answer it in real life? yesterday i was trying to refit the bulbs to the indicators on my car and i spend 35 mins trying to put them in the wrong way up. (the bulb holders where the wrong way up going into the back of the light, the actual bulb was the in correctly :wacko: )
Edited by hexhamstu
chris 417 mi
  Quote
hmm looks like the pipe has snapped off :wacko:, ill be ok just blanking it off though wont i ?
