JimLad
Coil Spring Platfrom Rotating Freely
JimLad
This might be a really silly question, but just gone to replace a broken spring and found the platform is free to rotate on the damper. Is this right??
Tempted to think sod it, the spring will hold it in place.
Any thoughts?
definitely not right!
Spiky
asuming these are std type shocks, thats a VERY bad thing, and either needs replacing, or at least welded in place
assuming you are talking of the lower platform?
if it is and fails that front corner of the car will hit the floor
imagine that at 70mph :D
JimLad
Yes, it's the lower platform that the spring sits on and they're OE Peugeot ones. The platform can't move vertically because of a form in the damper body, but it can rotate which is the problem.
Spiky
i wouldnt drive that dude,
take the shock off and get it welded at the very least, or just get a new one to be on the safe side
JimLad
New one it is then! Thanks for the advice everyone.
don't forget that suspension and brake components like dampers and springs, brake pads and discs, should be replaced in axle sets.
Tack it on with a blob of MIG weld, the collar stops it moving up and down, you just need to stop it rotating. Wants to be a quick blast to tack then leave it to cool. Then do another one on the opposite side.
