Gavin Waddell
Misfire
Gavin Waddell
mz 1.9 has developed a wired miss fire, when the car is cold it is fine as soon as it gets up to temp aftera few miles its starts to stutter when under a load and want to cut out, if i accelerate hard it cuts revs then dies. The engine was rebuilt and i ran it in for a 1000miles, withno problems. I changed the water temp sensor to the ecufor a spare one that i had and will that improved the problem a bit but not much. also on the misfire it bangs a lot lke its over fuelling.
Gavin
munster
Sounds very much like a dodgy ignition amplifier..
Roman
Gavin
try change ignition amplifire....
Gavin Waddell
i will change the amp for a spare one that i have lying around, the other thing is tyhat ive never had heat paste on the amp, its alwazs been fixed to a big aluminium plate to dissapate the heat.
kate205gti
ditto ignition amp :D worth trying a known good one just to be sure!
large
Water temp sensor,when engine is up to temp it is then over fueling. To test just unplug whan up to temp.
Edited by large
MerlinGTI
Mines just started doing this within the last week ! ECU temp sensor is brand new (changed it a fortnight before the problem began) So im too going with ignition amp.
Make sure you get a bosch one mine, I put a GSF one (Hugo) on and it created a missfire all thrugh the rev range.
