timmsy19 3 Posted December 25, 2008 bit of a stupid question but does anyone know how to tighten up the PAS belt on the mi16. ive not got a haynes that covers this. pics would be usefull thanks Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted December 25, 2008 Same as on a diesel 205, can't help with pic's atm but; Loosen the pump mounting bolts through the mounting bracket on the gearbox. There is a 1/2" square drive hole (iirc) in the mounting bracket near the aft end of the pump. With asuitably sized extension, turn so the belt tension increases. Holding the tension, tighten the upper aft mounting bolt (iirc 16m). If the tension is enough, tighten & then tighten the lower aft & forward bolts. Graham. Share this post Link to post Share on other sites
timmsy19 3 Posted December 25, 2008 thanks Graham. this will be my mission this weekend Share this post Link to post Share on other sites
