Kennyb 0 Posted December 19, 2008 Hi Guys Ok i've a leak from the oil cooler........just wanting to know how to change it and how the thing works so I can sort it out ;-) Done a search but there isn't much about fitting and any specifics about method for when I change it Any help much appreciated ;-) Cheers Share this post Link to post Share on other sites
dcc 855 Posted December 19, 2008 only know from removal of mine... screws into an extension of some sorts between the block face and the oil filter. i removed mine as i didnt feel it was needed. Share this post Link to post Share on other sites
omega 82 Posted December 19, 2008 as dc says theres a sandwich plate between the oil filter and engine which you can remove and just use the filter,but check the pipes as sometimes they fracture Share this post Link to post Share on other sites
Kennyb 0 Posted December 20, 2008 o yeah its a 1989...(1.9 obviously) Share this post Link to post Share on other sites
mattbenselin 0 Posted December 21, 2008 On mine there is a rubber seal which sits between the filter mount and the block itself, when I took mine off it was split and needed replacing. This could be the cause, whether it is or not you can do no harm by putting a new one in. Share this post Link to post Share on other sites
jord294 95 Posted December 21, 2008 there's also 2 little seals which fit over the oil cooler pipes which mount into the sandwich plate Share this post Link to post Share on other sites
