charlo99 0 Posted December 19, 2008 my clutch is f***ed at the moment pedal on the ground,the cable is still in 1 piece, it was giving me a bit of bother for a while i thought the cable was goin so i would adjust it a bit and it was fine for a bit then it would go again i'd adjust it an fine again. but now the pedals on the floor,had a look and noticed the bracket that holds the cable in the engine bay was pulled forward but looked to me like it needs to spring back or something have a pic of it but dont no how to post it with this Share this post Link to post Share on other sites
Goliath 94 Posted December 19, 2008 Sounds like your clutch release bearing has gone or the clutch is just well gone! It will need replacing with a new item. You post pics by using the [/img] code Share this post Link to post Share on other sites
charlo99 0 Posted December 19, 2008 Sounds like your clutch release bearing has gone or the clutch is just well gone! It will need replacing with a new item. You post pics by using the [/img] code cheers i thought it was that ,how easy is it to fix? Share this post Link to post Share on other sites
charlo99 0 Posted December 19, 2008 Sounds like your clutch release bearing has gone or the clutch is just well gone! It will need replacing with a new item. You post pics by using the [/img] code still cant get pics up Share this post Link to post Share on other sites
M@tt 77 Posted December 19, 2008 cheers i thought it was that ,how easy is it to fix? depends how handy you are with the spanners and whether you have all the tools ie braker bars, hub nut sized socket have a look here http://205gtidrivers.com/articles.php?data=s-clutchchange if its the first time youve done it put aside a weekend to be on the safeside Share this post Link to post Share on other sites
charlo99 0 Posted December 19, 2008 depends how handy you are with the spanners and whether you have all the tools ie braker bars, hub nut sized socket have a look here http://205gtidrivers.com/articles.php?data=s-clutchchange if its the first time youve done it put aside a weekend to be on the safeside thanks for the info great help Share this post Link to post Share on other sites
steve@cornwall 100 Posted December 19, 2008 HOLD ON!!!! Is yours a BE1 gearbox? (lift up reverse) If so first check that there is a 70m long 6mm diameter bar fitted between the clutch arm on the gearbox and the L shaped lever the cable goes into - these often drop out if the cable is too slack. Also the L shaped lever can bend/ break Both will give your symptoms and are easily sorted as long as you can get the parts easily Share this post Link to post Share on other sites
charlo99 0 Posted December 19, 2008 HOLD ON!!!! Is yours a BE1 gearbox? (lift up reverse) If so first check that there is a 70m long 6mm diameter bar fitted between the clutch arm on the gearbox and the L shaped lever the cable goes into - these often drop out if the cable is too slack. Also the L shaped lever can bend/ break Both will give your symptoms and are easily sorted as long as you can get the parts easily no its not lift up reverse Share this post Link to post Share on other sites
M@tt 77 Posted December 19, 2008 also have a look at this one http://205gtidrivers.com/articles.php?data=s-gearboxswap Share this post Link to post Share on other sites
steve@cornwall 100 Posted December 19, 2008 no its not lift up reverse Box off then Share this post Link to post Share on other sites
charlo99 0 Posted December 19, 2008 also have a look at this onehttp://205gtidrivers.com/articles.php?data=s-gearboxswap sound out your a legend Share this post Link to post Share on other sites
charlo99 0 Posted December 19, 2008 Box off then its looking like that not what i need just b4 crimbo Share this post Link to post Share on other sites
Goliath 94 Posted December 19, 2008 its looking like that not what i need just b4 crimbo If you werent in Ireland I would offer to come do it for you! Share this post Link to post Share on other sites
charlo99 0 Posted December 19, 2008 If you werent in Ireland I would offer to come do it for you! ireland is lovely at christmas Share this post Link to post Share on other sites
