matty_gti 20 Posted December 17, 2008 Hi all, well slowly but surely im getting all my bits done but having a look at these I am wondering if there worth re-painting etc as when they were on my TT I had no problems, just look a bit rusty and flaking in places!. Let me know what you think. Thanks. Share this post Link to post Share on other sites
welshpug 1,675 Posted December 17, 2008 (edited) how old are they? might be worth an email to Bilstein or SBC to see what they can do for you, if theyre as old as they look they probably could do with a refresh internally too (if possible, not 100% is these ones can be?) Edited December 17, 2008 by welshpug Share this post Link to post Share on other sites
Miles 331 1 Cars Posted December 17, 2008 (edited) Christ, that looks bad to the extent they must be the worst I have ever seen. 50/50 you could take the inserts out if they are that type and get the bodies blasted and see what they are like then and go from there Bilstein UK don;t get involved in rebuilds Edited December 17, 2008 by Miles Share this post Link to post Share on other sites
matty_gti 20 Posted December 17, 2008 (edited) Thanks for your input guys, I though they looked bad. Ive given them a quick bead blast and a wire brush allready and I can pick off those large flakes at the base with a screwdriver . Edited December 17, 2008 by matty_gti Share this post Link to post Share on other sites
andychalmers 0 Posted December 18, 2008 They look really bad, I would'nt really want to run them incase they broke. Plus if the bodies are that bad im sure the internals and knackered. See if there is any play between the insert & the body, then strip insert out and put 2 of them back to back and see how soft they are, if there soft then there knackered. You normally need your full body weight on only 1 insert to get it to compress. If you need bushes fitting I guess there about £50 per shocker, if you need inserts you cannot buy the fast road ones on their own but you can buy tarmac or gravel competition inserts which are about £110 each I think. Share this post Link to post Share on other sites
