McDude 33 Posted December 16, 2008 My Pug has developed what can only be described as a wandering problem - it suppose could be described as like it's tramlining. On Motorways it is most noticable, but not exclusive to this. Driving at say 70 under constant throttle, the car will tug slightly one way, requiring a small correction. it will then pull slightly the other way, again requiring correction. It is a very unnerving feeling and definitley not right. The problem is exacerbated by the throttle - ie lifting off and applying throttle makes it pull left/right more. I'm thinking that a bush has gone or perhaps a balljoint - there is no clonking though to point directly to which one. Any ideas where to look first? Tests to determine fault? Top mounts and shocks are all less than 6000 miles old and there doesn't seem to be any play in the rack. Tracking was done at the same time and tyres are all new. Thanks. McDude Share this post Link to post Share on other sites
Tom Fenton 1,561 Posted December 16, 2008 Wishbone bushes, wishbone ball joints, ovalled hubs, knackered TRE's, rear beam play in trailing arms, check in that order in my experience. What you've described sounds like classic wishbone bushes but could be any of the above. Share this post Link to post Share on other sites
notamondayfan 44 Posted December 16, 2008 id second that, wishbone bushes. best way to check is to jack up one front corner so the tyre isnt in contact with the ground. then grab the tyre at the top and bottom and try to wobble it back and forth. if theres movement then its probably knackered. Share this post Link to post Share on other sites
McDude 33 Posted December 16, 2008 I'll look into the wishbone bushes first - a crap job in this weather. Should i expect a clonk if one is gone? I went looking for bumps and potholes to try and make it clonk but it sounds tight all round. Just interior creaks! I take one thing back though - I've been out for a drive in it since the first post and wonder (though it could easily be in my head) if there is play in the rack. You can sit still and move the wheel a good bit left/right before if sticks. Is this normal? About 10 degrees of movement off centre either way. Share this post Link to post Share on other sites
Tom Fenton 1,561 Posted December 16, 2008 Bushes can be worn enough to cause wandering without clonking. Share this post Link to post Share on other sites
Toddy 8 Posted December 16, 2008 Has the wandering only happened recently, If so check that the rack is secure as this could be causing the vagueness Share this post Link to post Share on other sites
1 FAT PUG 39 Posted December 16, 2008 mine does the exact same thing, only started since i put pattern bottom arm on as the original had play in it, so going to get one from scrappers tomorrow, typical i got one on a subframe but the bolts siezed in Share this post Link to post Share on other sites
McDude 33 Posted December 18, 2008 Wishbone bush as you'd all predicted! TREs are a bit worn too - nothing major, but have a little bit of movement. Will get round to changing the4m in the new year. Thanks dudes. Share this post Link to post Share on other sites
