spike
Vinyl Trim On Rear Edge Of Front Door
spike
Hi chaps, I need the black vinyl trim that goes on the rear edge of the front doors. I've asked at Peugeot main dealer and they say it's no longer available.
Any help would be appreciated.
Mike
Dan Ingram
I could also do with one of these if they are available.
Rom
I thought they were available, but cost a fourtune.
Anyway, think a common thing is to satin black that area for a similar effect. Im wonderign what to do with mine as its being painted. I might see if i can order one off a Toyota at work, havent checked if they come seperate yet :D And then just trim it to fit.
Cut some black vinel to suit not much more you can do now, Some models where just painted anyway but I think it looks better body coloured
Henry Yorke
Run black electrical tape down them. Degrease the surface before applying and make sure one edge is tucked under the window rubber. You will be suprised by the results! If you really don't like it you can peel it off and have lost nothing. I have done this on a non-GTI before and it lasted for years
Last Legend
Could you get some of the correct strips from another later model ie: a 106
spike
I thought about 106 trims last night. I'll try Peugeot later.
Mike
cRaig
I got a set from peugeot in september, cost about £12 each if I remember, so you are probabally better getting a set off a 106 or something, bound to be cheaper.
de Noir
Got mine from Peugeot spare parts, but it was long time ago.
It's a 3M self adhesive foil with black matte grained finish, you should be able to get it at any better foil-cutting-quick-design-print shop.
vicious-monkey87
any local graphics shop should be able to fit vinyl for about a fiver for both sides! mine will need done when i'm mot'd and i've been quoted £6 for both sides and that includes fitting them!
Rom
Looked at mine today while stripping it, mine are painted both sides, i assume from standard.
Personally i prefer them black, rather than body colour. So ill prob sort something out after its painted.
