unariciflocos 49 1 Cars Posted December 14, 2008 I have a 205 Rallye DFZ. I've changed the head to a D9B ported and polished, 11.5 CR, Kent PT23 and I'm almost done with the Inlet manifold for GSXR 1100 Mikuni carbs. After everything was in place, except carbs, I wanted to see if electrics were ok so I turned the ignition and got nothing. I heard some relays turn, the fuel pump went on but the starter motor wouldn't engage the flywheel or turn. I kept turning the ignition on and off and got the starter motor to turn for a fraction of a second two times. After that i would turn the ignition again and the fuel pump wouldn't turn on again. I changed the battery, I checked the wiring and everything seems to be ok (battery, alternator, starter motor are properly connected; all connectors related to the injection system are not connected). At one time the ECU went crazy and dash dials were twitching. I really can't find a pattern or a possible cause. Sometimes the fuel pump turns on, most of the times id doesn't. What am i supposed to do with the ECU now that I've switched to carbs? What could be the problem with the engine not starting? Thanks, Andrei (I know my explanation is a bit confusing but I'm still hoping some of you can understand and maybe help ) Share this post Link to post Share on other sites
hodgy 0 Posted December 15, 2008 you dont need the ecu anymore now so you can throw it away what have you done with the fuel pump? used 2 regulators to bring down the pressure or used a fascet pump and filter king? Share this post Link to post Share on other sites
MrG 3 Posted December 15, 2008 disconnect the ecu at least. I just removed the ecu, and the injectors etc, left the wiring there bagged up and out of the way (I'm afairy where wirings concerned) and fitted the carbs. Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 15, 2008 I picked up my inlet mani today and will be mouning the carbs today and will be going for first fire. I am going to run the std fuel pump and just run a "T" with the return (the kind you use for the windscreen washers). A friend of mine used the same thing on his R1 carbed CVH Fiesta and works perfectly. As for the loom I'm going to leave it in place, i will just disconnect the ECU. As for the starting problem, I've been searching the forum for the last three hours and found that my problem could lie with the brown multiplug, or a dead starter motor. I've checked both the brown connector and the blue wire going to the starter motor several times and they seemed ok so most likely i have a dead starter motor. Will be doing a more thorough check with some extra wires and multi-meter this afternoon after i get off work. I really hope i sort it out one way or another because I'd really love to have a first run today. Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 15, 2008 Apparently the starter motor was full of water and it didn't quite like that Engine started as soon as the carb chambers were full with fuel even though I didn't take the time to adjust the dizzy. Fuel was spraying out from every hole, the standard pump is just too much, i got some coolant spraying from the two little holes that go from the head to the std inlet mani, and haven't got to making the vacuum outlet yet. But apart from these little things that need to be sorted out everything is fine and dandy. If anyone want to see my work: and first fire http://www.youtube.com/watch?v=N_O0ODpmkOY how much power do you think I got using this setup: GSXR 1100 carbs, 11.1 CR, Kent PT23 304 deg, port and polished head, 3 angle valve seats, std bottom end? Cheers guys Share this post Link to post Share on other sites
notamondayfan 44 Posted December 15, 2008 you can cut off the injectors wires, i did this on my conversion and its perfectly fine, and makes it a little tidier. just make sure to insulate the wire ends just incase theres a small chance of shorting something. Share this post Link to post Share on other sites
MrG 3 Posted December 15, 2008 have you fitted a pressure regulator? The inj pump will be far to much for the carbs, so get one and fit it asap (or replace the pump with a red top, but do a search as its been covered a few times before) Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 16, 2008 (edited) I put the wires i didn't need from the loom in a back, put a cable tie around them and concealed them near the brake drum in case i should need them in the future. There will be no cutting . I noticed the fuel pressure was too high, fuel was spraying out every hole of the carbs. Will get a pressure regulator today. Also on the list for today: -making an accumulator for the vacuum, a pipe 40mm in diameter, covered at both ends connected to all 4 intakes. -drilling the jets 1.6 or 1.7 but may have to go 1.8, will go in incremental steps and see how it runs -smoothing out the inside of the inlet manifold where the welding was done (good diy job, but needs a little bit of tinkering) -if I don't get proper results with the dizzy I might install a Megajolt system from a friend. again,how much power do you think I got using this setup: GSXR 1100 carbs, 11.1 CR, Kent PT23 304 deg, port and polished head, 3 angle valve seats, std bottom end? Thanks, Andrei Edited December 16, 2008 by unariciflocos Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 16, 2008 I've built the vacuum tank and sorted out the fuel pressure but now it doesn't rev I hit the throttle and it goes to 3500 RPM after which it drops, and I have to let the throttle down and hit it again for it to go up again. I don't know what the problem is. Could I have installed the camshaft wrong? I used the std pulley and set the timing belt on the std markings. Or is it a fueling issue? Please help guys. Thanks, Andrei Share this post Link to post Share on other sites
projectpug 0 Posted December 16, 2008 (edited) Ignition timing and fuel would be my first thoughts. Im pretty sure you need a adjustable vernier cam pulley to time up a pt23 its fairly "wild". Power when timed correctly and with a good ignition curve and carb jetting i would say between 145-160 ish depends too much on the head a poorly ported/polish head will be worse than stock peugeot. Edited December 16, 2008 by projectpug Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 17, 2008 Ignition timing and fuel would be my first thoughts. Im pretty sure you need a adjustable vernier cam pulley to time up a pt23 its fairly "wild".Power when timed correctly and with a good ignition curve and carb jetting i would say between 145-160 ish depends too much on the head a poorly ported/polish head will be worse than stock peugeot. Is there a guide to how I should adjust the cam tming? Should I advance the cam? Will be increasing jet size today and fiddling a bit more with the fuel pressure and ingnition timing. Share this post Link to post Share on other sites
projectpug 0 Posted December 17, 2008 Hi, I would leave the cam timing for now. Start with the things you mentioned and also check your not getting more than 5psi to the carbs. If you can make a video and post a link would be helpfull to me and anyone else who can help. Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 17, 2008 Could i get away with using a mechanical fuel pump? Will do some more work tonight after work. Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 18, 2008 Does anyone know what pressure the std injection electrical fuel pump and the carburetor mechanical fuel pump supply? Share this post Link to post Share on other sites
welshpug 1,668 Posted December 18, 2008 standard injection pump just pumps, the regulator controls the pressure (3 BAR/21 psi) and any excess goes back to the tank via a return. carbs on a 205 IIRC require a max of around 5psi. Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 18, 2008 Will a standard mechanical fuel pump from a carburetor 205 provide enough flow for my 4 carbs? Share this post Link to post Share on other sites
MrG 3 Posted December 18, 2008 why not just get a regulator like wp says. My carbs run spot on at 5psi Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 19, 2008 (edited) Well the answer is quite simple, mechanical fuel pump - free, fuel pressure regulator - 80 Euros. Might as well give it a try before I go ahead spending money. I've drilled the thermostat and dizzy housing and put the pump in. Will be testing tonight. I bid on a Megajolt system on ebay but the guy said he won't ship to Romania I have 100% positive feedback. Peoples preconceptions are so frustrating sometimes. Edited December 19, 2008 by unariciflocos Share this post Link to post Share on other sites
MrG 3 Posted December 19, 2008 they are you're right. Good luck on it. Share this post Link to post Share on other sites
projectpug 0 Posted December 21, 2008 Welshpug is correct 5psi max for carbs any more will damage the carbs and increase the risk of fire. Regarding the 205 carb pump i dont know as the most popular method here is to used a dual regulator set up. I have mine set at 4.5psi and it runs fine. The other way is to install a facet red top . But i suppose there is no harm in fitting the mechanical one and then seeing how you get on. Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 22, 2008 I junked the mechanical pump idea and fitted a T coupler between the hose from the filter, return and hose to the carbs. I'm using a ring on the return hose to adjust the pressure. I know it's a crap solution but it works for now and i can do my testing. Is this pressure regulator ok? Or should I go for something better? I took the car out for a spin yesterday, and although i didn't take the time to adjust ignition timing or the carbs it ran really good with really good power from 3k rpm up. I heard a local garage installed the first RR in our city while I was in the UK and I hope the have someone qualified to properly set my car up. The engine and cooling hoses were really hot after the first run, but I didn't get a reading higher than 80 deg C on the dial so I guess that's fine. I'm pretty ok with how things are at the moment. Will be getting an oil cooler, a baffled sump and a Megajolt system by spring and then it's fun time. Share this post Link to post Share on other sites
projectpug 0 Posted December 22, 2008 (edited) http://shop.ebay.co.uk/items/_W0QQ_dmptZUK...r&_osacat=0 The one you show is a Fuel injection one . The FSE is a very good carb regulator imo. Edited December 22, 2008 by projectpug Share this post Link to post Share on other sites
unariciflocos 49 1 Cars Posted December 22, 2008 (edited) Tinkered a bit more with the engine today and did a few test runs. It packs quite a punch at 3k 3.5k rpm and then keeps going. One of the drive shafts went kaput though, started rattling like hell. I have a spare but I'll be taking a break until after Christmas when I'll also be installing a Megajolt kit from a friend . Thanks for all the help guys, merry Christmas and a very happy new year! Edited December 22, 2008 by unariciflocos Share this post Link to post Share on other sites
projectpug 0 Posted December 22, 2008 No problem, Merry xmas and happy new year too! Share this post Link to post Share on other sites
