Guest leejd
Will Gti Clocks Fit Into Uk Rallye
Guest leejd
hi all
im going to a 205 breakers today just wanted to know as my 205 rallye dosent have a temp gauge or oil gauge will the gti clocks fit in or will i need to change bits on the loom to make it work
calvinhorse
you will need the dash suround as the rallye is the same as a base model, and the wireing loom from the fuse box to the dash which all just unplugs, you cant go wrong as the plugs will only fit one way!
the speedo cable fits but needs moving over to the left hole behind the dash.
im not sure if the revcounter and water temp will need rewiring???
the oil pressure switch on the block will need changing for a sender
the fuel gauge will work :)
edit- water temp will also need a sensor as it only runs a warning light, i used the one off a 1.6 gti
Edited by calvinhorse
