dean 0 Posted December 12, 2008 has any one fitted a cage in a car with a sun roof and if so was it stoo use able or do you have to take the sun roof out and plate the roof Share this post Link to post Share on other sites
Tom Fenton 1,544 Posted December 12, 2008 Yes, and yes the roof still works. Share this post Link to post Share on other sites
Cameron 16 Posted December 12, 2008 Depends what cage and what sunroof I guess. My Safety Devices wouldn't fit around my crappy pop-up sunseive as the roof diagonal fouled the handle. Luckily its a weld-in so I could leave that bit out until I ditch the sunroof. Share this post Link to post Share on other sites
marksorrento205 80 Posted December 12, 2008 How about an omp 10 point bolt in and a sliding sunroof? Share this post Link to post Share on other sites
projectpug 0 Posted December 12, 2008 Hi, Had omp 10 point in mine (bolt in but weld in plates) with sunroof fitted fine and roof still worked great on track on a hot day lol. I have however plated it up now but it was fine. Share this post Link to post Share on other sites
marksorrento205 80 Posted December 12, 2008 Sweeeeeeet Share this post Link to post Share on other sites
Stu 18 Posted December 13, 2008 Yeah ive got a 10 point in mine mate, sliding roof still works fine too You do need to remove the sunvisors, and i got rid of the interior light to get a bit more room. I also got rid of the inner gaurds from the rails on the inside as they were a little close. Share this post Link to post Share on other sites
Guest sam-black Posted December 16, 2008 I've got a 10-point OMP bolt in cage with full slide back sun roof and it works no problem! Only issue i've had is that the cage has been rubbing on the rear drainage pipes for the sunroof causing a leak inside when it rains. This could of been done when it was installed but just thought i'd mention it if it helps at all Sam. Share this post Link to post Share on other sites
