Namder 0 Posted December 11, 2008 hi all, just fitted a be3 box to my car it was a be1 i was given a cable off a be3 but it was broke so i stripped the ends off the clutch arm end and transfered them onto my be1 cable this has worked but only just i need to have more adjustment then this cables gives me plus i noticed the peddle end is different mine has a metal pin holding it. is there a cable with the correct ends if so what does it fit thanks all Share this post Link to post Share on other sites
jonnie205 1 Posted December 11, 2008 for a be3 box use a be3 cable and clutch pedal Share this post Link to post Share on other sites
Baz 421 Posted December 11, 2008 You ideally need the be3 pedal too, aswell as the correct cable yes. Share this post Link to post Share on other sites
welshpug 1,666 Posted December 11, 2008 you can modify the pedal easily enough, 2 cuts with an angle grinder Share this post Link to post Share on other sites
Namder 0 Posted December 15, 2008 you can modify the pedal easily enough, 2 cuts with an angle grinder i man after my own hart!!! is there anything i sound know or will it all become clear? thanks all Share this post Link to post Share on other sites
