bill 0 Posted December 11, 2008 As title please guys, does anyone know where you can get the mounting brackets for an omp bolt in roll cage. had a quick look on mp website but couldn't find anything cheers Share this post Link to post Share on other sites
welshpug 1,675 Posted December 11, 2008 Try the OMP importers/distributors http://www.ybracing.co.uk/ Share this post Link to post Share on other sites
Batfink 201 Posted December 11, 2008 (edited) I tried to use YBRacing but it was a painfull experience for both of us. One of my distributors has just started stocking OMP so i use them when I dont want to order large amounts direct from Italy. Not sure if the mounting brackets are sold separately but i can ask as i need to get a couple of steering wheels in. Edited December 11, 2008 by Batfink Share this post Link to post Share on other sites
bill 0 Posted December 11, 2008 cheers folks, looking into ybracing, but not sure which bits i need as i've not seen the cage as yet, pm'd batfink Share this post Link to post Share on other sites
boombang 2 Posted December 11, 2008 Easy enough to make. On the basis you have to weld them in (therefore assume you can either weld or using someone who can to install them) just get some 3mm plate and make them up to fit as best. Share this post Link to post Share on other sites
bill 0 Posted December 11, 2008 boombang said: Easy enough to make. On the basis you have to weld them in (therefore assume you can either weld or using someone who can to install them) just get some 3mm plate and make them up to fit as best. worst case scenario, i'll do that mate Share this post Link to post Share on other sites
Spiky 37 Posted December 11, 2008 they crap anyhow matey, i'd would just custom make them when i had my cage fitted they were altered like triggers broom ..lol Share this post Link to post Share on other sites
large 33 Posted December 12, 2008 Got mine from demon tweeks but cost££££££££ I dont think OMP do a fitting kit for the 205 you just get a universal one so some adjustment may be needed. Share this post Link to post Share on other sites
16v205 9 Posted December 12, 2008 The OMP plates need a little working to fit the car anyway as they are only a rough cut, its no big deal with a angle grinder and only takes a few minutes per plate. If it was me id not pay silly money to OMP for replacements id be down my steel suppliers with a card board template. Your always going to have to gring the plates to make them fit properly anyway so save a few quid and just grind a little more off. If theres a few of you needing these and you get really really stuck Ill work out a supply cost for these plates with the bends already done, pre-drilled and the captive bolts welded on. Rich Share this post Link to post Share on other sites
ORB 227 1 Cars Posted December 12, 2008 I cut off all of the cage above the original feet, and welded up my own, they were a lot easier to fit and I think they work better. Share this post Link to post Share on other sites
marksorrento205 80 Posted December 12, 2008 I have just been asking ybracing about the same thing and they said there is no mounting kit available but said to use AA/175 which I think would do for the front mounts, dont know about the rear's, and they cost £6.74 ea. Im wondering how much a bit of 3mm steel sheet will be. The brackets they say are not even drilled with welded nuts. Im thinking for the price of these brackets which is a bent piece of 3mm steel, it would be cheaper to make your own. Share this post Link to post Share on other sites
