supersub14
Is There A Difference Between A 1.6gti And 1.9gti Back Axel?
supersub14
Hi, as title says -
Are the back axel (including brakes etc) exactly the same for a 1991 1.6 205 Gti and a 1992 1.9 205 GTi?
Straight swap or will i have to change any parts? :huh:
the brakes, stub axles, and front mounting brackets are different, all interchangeable though.
supersub14
Cheers :)
What about a 309 back axel? I dont know anything about them unfortunately. Never seen one.
I assume they come in a 1.9 version that would be straight swap?
Jrod
The same but wider.
djinuk
309 rear axel's are often fitted to give the car a wider track, will fit though
And bigger torsion & anti-roll bars...
C_W
I think it might be worth saying why you're asking as ANY rear axle will fit any 205. A 1.9GTi has rear disc brakes vs drums of the 1.6. The 309 setup will bolt on too but it's wider and it's also quite a bit stiffer
supersub14
Cheers for all the replies leds!
I need to change mine and was just wondering if there was any difference before i buy one. Good job i asked lol :)
Want to keep car original so ill just look out for a 1.9 one :(
