Guest liamcafs Posted December 10, 2008 I have an Mi16 in the 205 and have a few questions for folks with pressure gauges and Mi16's 1. What is you idle oil pressure? 2. What is your max oil pressure? 3. Does anyone know what kind flow rate they are getting from their pump, how quickly does you engine cycle its oil? 4. What is the minimum safe oil pressure for a Mi16, not talking about surge just safe min pressure. If you have any info on this I would be most grateful. Liam Mc Share this post Link to post Share on other sites
Jon_Bmw 13 Posted December 10, 2008 Normal driving: 70 psi cold idle 34 psi hot idle 65+psi when above 1500rpm and under load. Track driving: As little as 24 psi hot Idle(although I suspect this is more to do with the grade of oil- 10w40 semi) 55+ psi when above 1500rpm and under load. It does drop on long sweeping bends to around about 30, so we need to sort out a baffle sooner rather than later! I don't have the answers to questions 3 and 4, sorry. What are your figures for 1 and 2. Share this post Link to post Share on other sites
Guest liamcafs Posted December 10, 2008 I don't have answers yet but wanted to know for when I fit oil pressure monitoring equipment. I've not a lot of experience with the Mi16 and don't wan to lunch it Thank you, very helpful Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted December 10, 2008 liamcafs said: I don't have answers yet but wanted to know for when I fit oil pressure monitoring equipment. I've not a lot of experience with the Mi16 and don't wan to lunch it Thank you, very helpful iirc the oil pressure light illuminates at around 1-1.5 bar or so of pressure which is quite low. Share this post Link to post Share on other sites
Jon_Bmw 13 Posted December 14, 2008 BTTT for the OP. And i'm interested as well Share this post Link to post Share on other sites
Rob Thomson 6 Posted December 15, 2008 Can't remember the exact flow rate off the top of my head but have a vague memory it's something like 25 litres per minute. It's quoted in the official Peugeot literature about the XU9J4 engine, you might find a link to it on here somewhere... Share this post Link to post Share on other sites
Sandy 191 Posted December 15, 2008 That brochure document from Peugeot says (pigeon translation): At 120C oil temp: Pressure at 1800rpm 1.8bar Pressure at 6500rpm 5.5bar Max oil temp intermittent 150C Max oil temp continuous 140C Pump delivery at idle 8.2 litres/min Pump delivery at 6500rpm 16.1 litres/min Share this post Link to post Share on other sites
