justinv
Arth And Trim Removal
justinv
As said in the topic title I need to remove the side strips and arches is there a way to get the red strips out without damaging ? As mine are the old metal ones not the newer plastic ones.
Rom
If i remember correctly, the side ones are held on by clips that slide. Theres a little rod on the door itself, the clips sits over, then you slide it so it locks. The holes are elongated, so loose one end, tight the other.
So removal is a case of using a very small screwdriver or similar to get above or below the strip, and sliding the clips the correct way so they release off the rods.
Hope this makes sense....its early :ph34r:
