marksorrento205 80 Posted December 4, 2008 When fitting the gti6 gearbox you get the reduced lock. Where / what stops the rack giving the limited turn to the right on a std gti6 rack? I have a gti6 rack and am just wondering what bit I need to rob to limit my 205 rack? Any help would be great Share this post Link to post Share on other sites
welshpug 1,675 Posted December 4, 2008 its the PAS ram that prevents the wheel from turning as far, the rack itself is used on a few different engines but the Ram is specific to the RS engined models Share this post Link to post Share on other sites
marksorrento205 80 Posted December 4, 2008 Cheers welshpug. Ill take the ram off then. That will save space Anyone want a gti6 rack with out the ram? Share this post Link to post Share on other sites
chris-stdt 0 Posted December 4, 2008 I thought it was the bigger gearbox off the 306 that stopped full lock when turning one way but i may well be wrong Share this post Link to post Share on other sites
marksorrento205 80 Posted December 4, 2008 I thought it was the bigger gearbox off the 306 that stopped full lock when turning one way but i may well be wrong No you are correct but to stop the inner edge of the n/s wheel hitting / rubbing on the gearbox, a lock stop is fitted into the steering rack to limit the lock when turning right. Share this post Link to post Share on other sites
DanteICE 72 Posted December 4, 2008 Has anyone got any other ways of stopping the rack turning too far, maybe where a new ram could be purchased? Geoff Share this post Link to post Share on other sites
jonnie205 1 Posted December 6, 2008 make up and alloy bush and slide it onto actual rack inside body on os, the ti6 ram will be no good as the gti6 is wider ect etc so the ram wont limit enough Share this post Link to post Share on other sites
welshpug 1,675 Posted December 6, 2008 its not the width of the vehicle that affects the lock, its the offset of the rack from the centreline of the struts (same on a 306) and the distance from the inner wings to the pivot on the wishbone (I would hazard a guess that this dimension would be pretty damn similar too) Share this post Link to post Share on other sites
marksorrento205 80 Posted December 6, 2008 Im liking both ideas. As my ram is off my 205 rack at the mo and I have gti6 ram in the shed "when" I swap the engine and box its only two bolts to bolt the gti6 ram on. Then I will see if it limits it enough. If not a spacer it is. Share this post Link to post Share on other sites
jonnie205 1 Posted December 7, 2008 welshpug i know what you mean but i have fitted a gti6 ram to a 205 6 speeder and the ram does not limit the lock sufficiently Share this post Link to post Share on other sites
marksorrento205 80 Posted December 7, 2008 welshpug i know what you mean but i have fitted a gti6 ram to a 205 6 speeder and the ram does not limit the lock sufficiently What sort of size spacer are we talking about then. Do you have any pics of the spacer and where you have fitted it. Cheers Share this post Link to post Share on other sites
