Moz_Goodwood
2.0l Turbo In A 309
Moz_Goodwood
hiya all
does anyone have any experience in dropping a turbo lump in a 309???
is there any clearance problems on the brake servo / bulk head? like there is in the 205
i know in the 205 you can use the 306 xsi top mount and a modified standard bottom mount as this helps clearance, but i was wandering is it the same in the 309?
are the 309 engine bays slightly bigger? or are they the same as the 205
cheers in advance
paul
Same as the 205 in every way bar more room at the front,
The xsi mount is the same as most iron block engines, the mount needed depends on what car the engine came from.
Moz_Goodwood
it came out of a 406, so if it has a bit more room at the front will that mean there will be a little more room for the intercooler or are we talking millimetres
Again depending on intercooler type, you will have room for a better bend in the pipework, on the 205's it needs to be quite short when using the Cossie intercooler as in Matts project post.
The rad mounting should be easy too as again it is better than the 205 in that way
Moz_Goodwood
cheers for that mate :lol: some handy info
just one more thing to bend your ear on, will the exhaust match up as standard or will it need lengthening / shortning / welding etc
or is the only real way of finding out is just to get it in there
or is there a different exhaust that will fit? that can be used
Edited by Moz_Goodwood
No idea on that, I just got my exhaust man to make one up, but I would say the D/P would need shortening allot and maybe bending differently, I'm sure someone else will say for sure
Moz_Goodwood
does it matter which year the xsi is??? or are all the mounts the same
As said all XSi run the GTi6 type of mount, so any 306, 405 Mi16 Phase 2, ZX, Xsara, Xantia and no doubt allot of the PSA range will do
