philfingers 5 Posted December 3, 2008 I've forgotten but on the verticle brake i have is it the forward most port that goes to the back brakes and the rearward port that goes to the m/c? pretty sure it is but best check, Phil PS tried a search but didn't get very far Share this post Link to post Share on other sites
welshpug 1,675 Posted December 3, 2008 (edited) depends which is in and which is out. had a quick google, seems the front port is usually from the M/C (after brake limiter/bias valve if used) and rear port goes to the T-piece. found this - http://www.citroen.com/NR/rdonlyres/A218A3...alhandbrake.pdf Edited December 3, 2008 by welshpug Share this post Link to post Share on other sites
philfingers 5 Posted December 3, 2008 depends which is in and which is out. had a quick google, seems the front port is usually from the M/C (after brake limiter/bias valve if used) and rear port goes to the T-piece. found this - http://www.citroen.com/NR/rdonlyres/A218A3...alhandbrake.pdf It's a compbrake one. I just mailed them|! Share this post Link to post Share on other sites
Rob Thomson 6 Posted December 3, 2008 What make is the MC? They're usually set-up so that the port nearest to the lever/pedal is the outlet (to the rear brakes). If the MC is Girling/Lucas that's almost guaranteed. Share this post Link to post Share on other sites
jonnie205 1 Posted December 3, 2008 yep inlet at rear outlet at front Share this post Link to post Share on other sites
philfingers 5 Posted December 3, 2008 cool thanks guys, yes it's a girling (or copy) ! Share this post Link to post Share on other sites
