bizket205dimma
205 Gti Tt With Throttle Bodies?
bizket205dimma
hi quick question just bought a 205 gti 1.9 turbo technics dimma spent about £700 this week getting it up to scratch its now runing about 173bhp what i whanted to know is it possable to fit throttle bodies to a turbo'ed 205. would it be worth it.? would i get alot more power? what would i need i asume ide need a coustom made inlet manifold to fit the throttle boddies? also dose any 1 know where i can get the bonnet vent that is on the t16 or some thing simila?
thanks for your help in advance...
EdCherry
bonnet vent on the T16? there isnt one its rear engined....
Batfink
the 205 turbo16 had a big bonnet vent to duct the radiator hot air.
You can fit throttlebodies to a tt conversion, its been done before. You wont get a lot more power, might help on the midrange and throttle response but I've never seen rolling road printouts to compare.
You also wont be able to fit the bonnet vent as your engine will get in the way
ablister
205turbo had tb's on his tt engine
bizket205dimma
dose any one know if any 1 one hear has ant tb's for sale?? also has any one got an after market ecu???
kyepan
set of pulsar ones could be made to fit but it would be an arse ache to do the manifold.
bizket205dimma
theres a set of mikuni t/b's with45mm butterflys and 48 mm at the air box end there off a 106 gti would theese work?
also what are the megasquirt ecu's like what are the alternitives? how hard is to sort the loom out?
Henry Yorke
Personally I would look to put proper management on a TT first before looking at throttle bodies. This can release approx an extra 30 horses for you assuming the turbo and the rest of the car is up to scratch.
Throttle bodies can then be added later if need be and a custom airbox made.... it is going to cost you! However it can be done. Another alternative is to put a bigger inlet single throttle body on if it is more fuel you need. I know of a turbo'd Mi16 that runs successfully on a twin carb set-up too.
bizket205dimma
what manigament would be suitable? i have just had the car in at my local peformance center they checked every thing over and fount the 5th injucetor not working so they changed it from a 330cc to a 420cc injector and re maped the ecu its running at 173bhp a the moment ive orded a new intercooler to fit in the bumper grill so for now gonna consentrate on getting every thing sorted all the bushers rubbers ect changed ive got all powerflex for the whole car. then for acompleet engine rebuild and a respray after the new year. i just whanted to find a way to sqeese anouther 20-30bhp out of the car realy?
