mainline
Another Quick Caliper Question
mainline
I have decided to upgrade to 1.9 calipers. Have got the pads out, caliper bolts out, but I can't get the union housing at the end of the brake hose to undo at all. I have been using a 14mm spanner on it, but it won't seem to budge. Do they seize up a lot? All I seem to be doing is rounding the nut. I have sprayed WD40 on it etc, but getting nowhere. Any tips? Should I heat it up or something?
miamichris
WD40 isnt much use is this situation, i've found..plusgas is much better, spray it and let it soak for a while then see how you get on. If you round it, then use vise grips, it'll come out eventually! :lol:
mainline
Plusgas Formula A - is that the stuff? Got an itchy trigger finger about to "buy it now"
miamichris
sounds like it! its in a blue tin, its good gear too..its a penetrating oil whereas WD40 is just a lubricant :lol:
GLPoomobile
Another vote for Plusgas.
mainline
Have ordered some, got the aerosol version. Just want it to arrive before my new calipers (which should have been here yesterday grrrrrrrrr)!
Thanks for all your help.
