speedy indy 0 Posted November 29, 2008 I'm putting together my 1,9 8V engine after replacing the head gasket Underneath the throttle body housing there are 3 outlets to connect pipes to... which connects to the inlet manifold two of them come out in a V shape .... problem is i dont know where to connect these pipes to .... i know one goes back to the water reservoir.... not sure where the other one is supposed to be connected to ? any help would be appreciated hope this makes sense Share this post Link to post Share on other sites
welshpug 1,666 Posted November 29, 2008 the other goes to the small take-off on the thermostat housing just above the cover/top hose for the thermostat. 3rd will be for the Vacuum advance, if the vacuum advance is already connected some throttle bodies have an additional port for diagnostic purposes (to connect a Vacuum gauge to) this should be blanked off. Share this post Link to post Share on other sites
speedy indy 0 Posted November 29, 2008 Have had a look and still cant figure it out .....will take some pics later Anyone near heathrow have a 1.9 i can come and have a look at ? Share this post Link to post Share on other sites
Miles 331 1 Cars Posted November 29, 2008 Don;t connect them to the coolent, The top right pipe from the header tank goes on the small pipe above the themostat, Ditch the other pipe as it's no use in the UK The very small (Brass coloured) pipe is the vacume pipe which goes to the Dizzy. Share this post Link to post Share on other sites
