Guest okjc Posted November 27, 2008 think my head gasket has gone. symptoms..... water pressurizes slightly not like blow the cap off but a bit. temp gauge goes above half but not further than 3 quarters. and when it does go above half the heaters dont work? do you think this is the head gasket oil cap is not white but water is a milky orange colour? anyone help cheers? james Share this post Link to post Share on other sites
ablister 31 Posted November 27, 2008 try bleeding out coolant system and see if that helps Share this post Link to post Share on other sites
S13Nick 0 Posted November 27, 2008 air lock or no water, or blocked heater matrix Share this post Link to post Share on other sites
Guest okjc Posted November 28, 2008 how would i go about bleeding the water system? Share this post Link to post Share on other sites
BERTMAN 40 1 Cars Posted November 28, 2008 check out your hanynes, its simple enough... think the bleed valves are on the thermostat (allen key) and theres one towards the bulk head and its a lil screw cap thing... someone else wiill be able to remember better... Share this post Link to post Share on other sites
