SeanO'Connor 0 Posted November 25, 2008 Hi guys, doing a lot on my 1.6 at the mo, one question for anyone, is the oil temp sensor supposed to be in the sump? mine doesn't work, but I have found a wire which is probably the one, but the sump has no sensor in!!!!! Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 27, 2008 Yes, the oil temp sender is in the back of the sump. A friend had a new sump fitted to his car a few years ago & the garage didn't swap the sender across so he has the same thing as you. A spare wire (which they tucked nicely out of the way) & an oil temp guage that doesn't work. I keep telling him to take it back there & say he wats it fixing but he's to mild mannered for that. Graham. Share this post Link to post Share on other sites
SeanO'Connor 0 Posted November 27, 2008 Yes, the oil temp sender is in the back of the sump. A friend had a new sump fitted to his car a few years ago & the garage didn't swap the sender across so he has the same thing as you. A spare wire (which they tucked nicely out of the way) & an oil temp guage that doesn't work. I keep telling him to take it back there & say he wamts it fixing but he's to mild mannered for that. Graham. Thanks for that Graham, I will possibly just buy a sensor, and drill and tap the sump. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 28, 2008 What engine is in your car? If its just had a replacement sump of the correct type there is probably just be a drain plug fitted where the temp sender fits. If its got the wrong sump it'll probably be cheaper to find the corect sump instead of drilling & welding the correct threaded nut inside the sump so you can fit one. Graham. Share this post Link to post Share on other sites
SeanO'Connor 0 Posted November 28, 2008 What engine is in your car? If its just had a replacement sump of the correct type there is probably just be a drain plug fitted where the temp sender fits. If its got the wrong sump it'll probably be cheaper to find the corect sump instead of drilling & welding the correct threaded nut inside the sump so you can fit one. Graham. It's a 1.6 gti(91) there is only a hole for a drain plug on the sump nothing else. I could do the hole myself, no problem, I am a teacher at a FE college in the engineering department. But if someone has a sump cheap enough! Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 28, 2008 Isn't there a drain plug in the back of the sump? (not underneath) If not then you car has had at least a new sump fitted. I should have a spare sump for a 1.6 but it won't have a sender in. Thread is there but sender swapped to my 1.9 sump. Graham. Share this post Link to post Share on other sites
SeanO'Connor 0 Posted November 28, 2008 Isn't there a drain plug in the back of the sump? (not underneath) If not then you car has had at least a new sump fitted. I should have a spare sump for a 1.6 but it won't have a sender in. Thread is there but sender swapped to my 1.9 sump. Graham. Yes the plug is in the bottom, how much do you want for it? including P&P Share this post Link to post Share on other sites
BuD 0 Posted December 1, 2008 Yes the plug is in the bottom, how much do you want for it? including P&P But is there a hole on the back of the sump that is filled with a blanking plug? You need to know this to determine if you need a new sump or just a sensor? Share this post Link to post Share on other sites
SeanO'Connor 0 Posted December 2, 2008 But is there a hole on the back of the sump that is filled with a blanking plug? You need to know this to determine if you need a new sump or just a sensor? No there isn't a blocked hole, but like said if no-one has one i will just buy a sensor, and fit it to my sump. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted December 3, 2008 I've got a sump but it'll need an oil temp sender from Peugeot, part # 0242.50. I'll find it later today or tomorrow & be in touch. Graham. Share this post Link to post Share on other sites
SeanO'Connor 0 Posted December 3, 2008 I've got a sump but it'll need an oil temp sender from Peugeot, part # 0242.50. I'll find it later today or tomorrow & be in touch. Graham. cheers Graham. Share this post Link to post Share on other sites
