weejimmy 1 Posted November 25, 2008 i need the head bolt tightning sequance for a xud9 (306 1.9 dt) is there any websites etc that have this kind of info for free? fed up buying a haynes manual for every car i work on just to get tourque setings. or if anyone on here knows the pug setings etc? thanks Share this post Link to post Share on other sites
suth82 0 Posted November 25, 2008 (edited) The Peugeot recommended torques actually stretch the bolts which i think is bit severe, I tighten the bolts to 75 ft lbs in three stages - 25, 50 and 75 ft lbs. The tightening sequnce should be in a circle starting at the outside and working towards the centre. Edited November 25, 2008 by suth82 Share this post Link to post Share on other sites
Miles 331 1 Cars Posted November 25, 2008 Iron block bolt's are done tighter than the alloy ones, But no idea on the Derv models Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted November 25, 2008 Afaik 20Nm - 60Nm - 220 degrees Just did one of this engines, but can't remember the torques exactly, but 60-70Nm somewhere then 220 degrees I remember good Share this post Link to post Share on other sites
welshpug 1,666 Posted November 25, 2008 i need the head bolt tightning sequance for a xud9 (306 1.9 dt) is there any websites etc that have this kind of info for free? fed up buying a haynes manual for every car i work on just to get tourque setings. or if anyone on here knows the pug setings etc? thanks I must be the opposite lol, I have a 25 strong collection, nearly exclusively PSA aaanyway... Stage 1; 20 Nm. Fully slacken bolts. Stage 2; 60 Nm Stage 3; tighten through further 220 Degrees. Tightening sequence is the same as Alloy blocks, centre rear bolt is 1, front bolt 2, then work in a circle clockwise from there. The Peugeot recommended torques actually stretch the bolts Yep, that's what they're designed to do. Share this post Link to post Share on other sites
weejimmy 1 Posted November 25, 2008 woo hoo thanks welshpug (and everyone else) ill just go with the pug setings as they proberly know best. i know to do it in sequance etc just not sure of the settings 25 haynse mmm thats close becoming fetish Share this post Link to post Share on other sites
