cybernck
Is Coil On A 2000 306 Tu 1.4 And Xu 2.0 8v Engine Interchangeable?
cybernck
the title speaks for itself :rolleyes:.
they definitely look the same or at least pretty similar.
thanks.
I don't see why not - I've used both TU and XU wasted-spark coilpacks with Emerald ECU's using the same wiring without issue.
cybernck
excellent, cheers :).
does look like it'll even bolt on in the original location on the XU even.
Edit; checked part numbers 5970 70 IS the same coil for many TU engines as well as the XU10J2 :)
cybernck
sadly not this one - it has got a long coil just behind the head, plugged straight onto the plugs :).
5970 74 / 79
any other cars that share this?
doh!
that one is used on the TU1 in a 206, and the TU5 in the 306 +206 + partner, as well as the TU3.
