Cameron
Tubular Wishbone Project
Rippthrough
Or use a spherical bearing in a housing and a multi-piece wishbone like mine, that way you can get proper castor correction on there as well as camber.
Need to get some FEA software on this machine I think so I can show you!
Edited by Rippthrough
Cameron
That's definitely the best solution. I was thinking as I wrote that last reply that you would be best off using a spherical for the inboard rear and outboard, and possibly a rod end for the inboard front to get track / camber adjustability. You can then have separate front and rear links and use a rod end in the end of the rear link to give castor adjustability as that will always be loaded in compression. Of course that all depends on what anti-roll bar you're using!
Edited by Cameron
Rippthrough
My front ARB is sat in the corner of the workshop looking lonely :ph34r:
Cameron
Nice. :lol:
I'm determined to find a way to use it that doesn't involve designing a new one. Although I'll probably end up designing a new one. :ph34r:
Rippthrough
Well, I'm tweaking my design now for someone that wants to keep the stock ARB, I reckon I've sorted it, if it I works I'll show you.
Rippthrough
  Cameron said:
Cool, I won't steal it. :lol:
I wouldn't show you if that worried me!
davenport
rear mounts DONE-
next up...
jig a std wishbone....
TT205
Any further on this?
