JimLad 1 Posted November 24, 2008 This is annoying. just failed on a few little things, one of which was that when I put new gaiters on I used cable ties instead of metal clips. They're saying this isn't acceptable. Sure I've done this before and had no problems. Any testers on here? Share this post Link to post Share on other sites
welshpug 1,677 Posted November 24, 2008 tell them that many aftermarket CV boots and steering rack gaiters are supplied with Cable ties, FAI springs to mind, so I cannot see how their argument stands. if they are still being iffy on it I would speak to VOSA. Share this post Link to post Share on other sites
JimLad 1 Posted November 24, 2008 That's what I was just thinking! Annoying cos they've always been good before. Maybe it's just the bloke who did the test. Cheers! Share this post Link to post Share on other sites
Rom 0 Posted November 24, 2008 Im not a tester myself. But the testers at work pass tied boots. As far as im aware, they just have to be on / secured and not split. Share this post Link to post Share on other sites
Baz 421 Posted November 24, 2008 Exactly as above, it's not how they're secured or whether they're perished, just as long as they're not leaking. Share this post Link to post Share on other sites
Mikey S 29 1 Cars Posted November 24, 2008 tester here, as long as there securly mounted to the joint its a pass. are you sure yours arent loose when the wheel is on full lock? Share this post Link to post Share on other sites
CosKev 16 Posted November 24, 2008 As above,check to see if they are letting grease out Share this post Link to post Share on other sites
GLPoomobile 958 Posted November 24, 2008 I've seen the other topic about your harnesses. Tester sounds like a right prick! Here's my suggestion: 1 - Book it in for re-test at the same place 2 - When they say it's no good as the same faults apply, ask to see the gaffer 3 - If the gaffer agrees with the tester, tell them they better be VERY confident in their decision 4 - Call VOSA and inform them of the problems Share this post Link to post Share on other sites
mickie 3 Posted November 24, 2008 scouting for work, maybe? Share this post Link to post Share on other sites
ablister 31 Posted November 24, 2008 as above, get vosa involved. Sounds like they may be taking the piss Share this post Link to post Share on other sites
