markd6303
[project] 205 4x4 Mi16/gti6 Conversion
markd6303
here`s my attemp of making an alloy dash , idont know weather to paint it matt black, as i`m worried about the sun shining off it and blinding me.
you`ll prob notice i haven`t yet made the gear sellector rod and fixed it in yet.
i`ve just added another pic of the car nearly finished, as the one i added the other day is a bit on the small side.
http://i492.photobucket.com/albums/rr282/dicko2008/067.jpg
http://i492.photobucket.com/albums/rr282/dicko2008/058.jpg
markd6303
use photobucket its nice and easy ;)
thanks for suggesting photobucket thats much easier than the other way i tried.
Spiky
no problem, i want to see more pics of the car... ;)
looking awesome too :D
markd6303
think i have worked out how to put pics on now so watch this space,heres another little taster of the under side of the car.
markd6303
dan_cole69
sweeeeeeet :)
mickie
nice work, looks really clean and well put together that rear suspension
Edited by mickie
paul_portsmouth
just looked at your photo bucket wow
-_-:) :) ;):P:wub::blink::lol: :lol:
Edited by paul_portsmouth
stuart
That thing looks like a serious bit of kit, certainly puts my 4 year effort to shame :lol:
By the way, where did you get the roof vent from? I'm looking for one just like that for my rally car.
markd6303
the roof vent came off a 205 shell i bought off ebay, which i also got my dimma body kit off.
The roof vent is a carbon fibre one, which i had to spray as it was damaged by the time i had got it off the shell.
You can buy these at demon tweeks at around a cost of £250, or keep looking on ebay for one to come up for sale.
DrSarty
When and where was the engine run, and do you have a power/torque graph to show us?
Rich
markd6303
Just managed to spend a minute on the computer putting some more pics on as i have been busy
the last few days, as my wife gave birth to my daughter sophie weighing 7lb 9 on saturday, i`m totally
knackered.
markd6303
Rich
the engine was designed and built by neil at des developements.
It was originally mapped on an engine dyno producing 218bhp at 7800rp, But the mapping had to be aborted as we heard some
strange noises comeing from the bottom end.When it was took apart we found some unexspected problems
with the crank and bearings. So we decided to replace the standard one with a forged steel crank and race bearings as the others
would not stand up to the 9200rpm limit and compression of 12.1 which i am running.
So as you can see i still have not had the final mapping done, which when done with the engine spec should see between 250-270bhp at
the 9200 rpm rev limit.
very nice, Neal has built several nice engines with relatively little done do them recently :) (or at least that's what were lead to believe :lol: )
Edited by welshpug
tombo
ive just completely messed my underwhere i sex weed everywhere, that car is pure automotive porn.
fantastic work its an inspiration. :lol:
Batfink
Are they quite secretive as to the spec of their engines???
Henry Yorke
They build a lot of competition engines and like any good engine builder, don't splash all the details over the net. I know they do a lot of R&D and have exceptional customer service.
timmsy19
wow thats one nice project. good work. :lol:
tracktoy
congrats on the new addition to the family :)
cool project with great fabrication- should be a lot of fun when its finished
markd6303
Here`s the engine spec and some pic`s of the finished engine bay.
MI16 1.9 16V ALLOY BLOCK
PEUGEOT MOTORSPORT 405 BTCC STAGE 3 PACE DRY SUMP SYSTEM+DRY SUMP TANK,REMOTE OIL FILTER AND BREATHER SYSTEM.
SETRAB 16 ROW 235MM OIL COOLER
IAPEL 88MM FORGED STEEL CRANK
IAPEL 83.5MM FORED PISTON`S,PISTON RING`S AND RINGED LINERS
COPPER HEAD GASKET
COMPRESSION RATIOOF 12.1
CATCAMS FORGED STEEL ROD`S
CSL RACE BEARING`S AND SHELL`S
FIDANZA 3.4KG ALLOY FLYWHEEL
RADTEC ALLOY RADIATOR
HELIX COMPETITION 4 PADDLE CLUTCH+COVER ASSEMBLY AND RELEASE BEARING
NEW STANDARD STARTER MOTOR AND ALTERNATOR
NEW WATER PUMP
306 GTI-6 STANDARD HEAD(FOR NOW)WITH NEW VALVE GUIDES
CUSTOM BLANKED OFF OIL FILLER CAP
CATCAMS RACE CAMS INLET 293/285 DURATION 13.75MM MAXIMUM LIFT, OUTLET 260/252 DURATION 13.25 MAXIMUM LIFT.
CATCAMS VERNIER PULLEY`S
CATCAMS SOLID LIFTER`S
CATCAMS DOUBLE VALVE SPRING`S AND RETAINERS
MODIFYED OIL SPRAY BARS FOR CAMS TO CLEAR.
OMEX 600 ECU
JENVEY 48MM THROTTLE BODIES
PIPERCROSS AIR FILTER
BOSCH 375CC FUEL INJECTOR`S
SYTEC MOTORSPORT FUEL PUMP
SYTEC HI-FLOW FUEL FILTER
SINGLE GM COIL PACK
MAGNECORE 8.5MM RACE HT LEADS
MODIFYED LONGMAN 4-2-1 EXHAUST MANIFOLD
CUSTOM 2.5INCH STRAIGHT THROUGH EXHAUST SYSTEM WITH TWO ESCORT TURBO DEISEL SILENSER`S AND SINGLE SIDE EXIT PIPE
MODIFYED WATER HOUSING
SILICONE WATER HOSES
ALL THE OIL LINES AND FUEL LINES ARE GOODRIGED -12,-6 STEEL HOSE`S WITH ALLOY AEROQUIP FITTING`S
THIS ENGINE SPEC SHOULD PRODUCE BETWEEN 250-270 BHP AT 9200RPM REV LIMIT.
IT IS STILL WAITING FOR IT`S FINAL MAPING SESSION WITH NEAL WHO BUILT THE ENGINE FOR ME AT DES DEVELOPEMENTS.
Edited by markd6303
hexhamstu
wow.
calvinhorse
excellent project its gonna be a real monster!
do you have any pictures of the drysump setup?
Batfink
Going on the filter its the one made by Pace :D
