watford1gti 0 Posted November 21, 2008 might be a bit of a silly question but how do you remove them?? where are all the bolts holding it on, its always dark when i get to the garage and its too hard hunting for them?? is there any in the door shut? thanks for the help people matty Share this post Link to post Share on other sites
M@tt 77 Posted November 21, 2008 (edited) there are the bolts along the top where the bonnet cover, there is one/two in the door shut, one in the wheel arch and also where the bumper is secured on. If they are original wings then they will also be bonded on which can make getting them off a right pain without damamaging them. Edited November 21, 2008 by M@tt Share this post Link to post Share on other sites
mattbenselin 0 Posted November 21, 2008 Seeing as no1 else said anything yet....I took some wings of an AX the other day and they had bolts under the bonnet, near the door hinges and on the inside behind the front bumpers. Would presume the 205 is very similar. Just have a good look rounf sure you will be able to work it out. Matt Share this post Link to post Share on other sites
watford1gti 0 Posted November 21, 2008 cheers for that, yeah theyre original wings, ive already had a go at scraping some of the bonding out to try to make it easier, im gonna pull the motor out of the garage tomorrow and give it a go ill keep you updated matty Share this post Link to post Share on other sites
Peetypug 5 Posted November 21, 2008 get a heat gun of some form to soften the seam sealer Share this post Link to post Share on other sites
blue_haddock 2 Posted November 21, 2008 Slightly off topic but did you buy a couple of wings recently Pete? Share this post Link to post Share on other sites
Peetypug 5 Posted November 21, 2008 yes and i will be taking them back very soon they are crap!!!!!!!!!!!!!!!!!!!! Share this post Link to post Share on other sites
blue_haddock 2 Posted November 21, 2008 in that case i'll keep quiet! Share this post Link to post Share on other sites
watford1gti 0 Posted November 22, 2008 right had the motor out for a bit this morning, ive undone all the bolts in the wheel arch, and scraped all the sealer out from along the top, i think now the only thing holding it on is the inderseal behind the front panel, you say about a heat gun does that make it easier to scrape off? matty Share this post Link to post Share on other sites
