brian j 32 Posted November 20, 2008 As per my other topic I have just done a deal to buy a 205 that the owner says has an ABS fault. If I can't get it fixed then I will remove the ABS completely, but I want to start by working my way through trying to fix it. Unfortunately it isn't easy to search for ABS on the forum (only 3 letters, innit ) . I have trawled through previous posts but not found much. I am after any information to help me diagnose the ABS fault, but primarily: Any wiring diagrams, A list of fault codes and how to read them, (I believe that you can get the ABS light to flash the code for you.) Any anecdotes of the common failure points. The current plan is to start at the wheel sensors and check for a sine wave signal, then trace wiring back checking continuity and earths, then check over the ABS unit itself. Share this post Link to post Share on other sites
Rom 0 Posted November 20, 2008 Ive never worked on 205 ABS (thank god!) but generally sensors are the first place to look as you said. Check all the sensor rings are ok, clean etc. As they can through codes if broken / clogged etc as the sensor wont get a correct reading. As a mechanic, thats what i see the most. Ive had pumps and ecus go also. But 9 times out of 10 its a sensor. Im sure someone will be able to help out more, but im guessing its going to be a very basic system, so hopefully little to diagnose. Share this post Link to post Share on other sites
jackherer 543 Posted November 20, 2008 http://www.google.co.uk/search?q=abs+site%...5gtidrivers.com Share this post Link to post Share on other sites
brian j 32 Posted November 20, 2008 (edited) http://www.google.co.uk/search?q=abs+site%...5gtidrivers.com Sneaky. I'll bear that method in mind in the future. It did throw up a probable method of reading the fault code, but not much else. Any other assistance would be great. Edited November 20, 2008 by brian j Share this post Link to post Share on other sites
