Spiky 37 Posted November 17, 2008 whats the caliper model number thats fits under 1.9 gti wheels? i dont want t change wheels or run spacers Share this post Link to post Share on other sites
kyepan 291 Posted November 17, 2008 give AP a call and they should be able to help you out. they also have a fitment guide on their website. cheers J Share this post Link to post Share on other sites
saveloy 8 Posted November 17, 2008 I'm pretty certain that none of the AP range will fit under a std 1.9 rim. Share this post Link to post Share on other sites
kyepan 291 Posted November 17, 2008 (edited) considering they do custom jobs, i'm pretty sure they will, we spent some time trying to spec a kit that went under 15 inch pulsar alloys, and figured out which caliper to use. So looking at their site They do one for the 106 and the 206gti 6, both using the same caliper, as you can see from the details below, the 106 fits under 15" compomotives, and the 206 gti 180 brakes bolt straight onto the 1.9 so they have the brackets for both the caliper and our 1.9 hub. Quote Peugeot - 106 - Front 4 Piston Kit CP5100-1004 Black Caliper Kit Number - CP5100-1004 Red Caliper Kit Number - CP5100-1004R2 IMPORTANT NOTE: Before purchasing or installing a formula big brake kit, make sure that the brake upgrade is suitable for the make and model of the vehicle, and that the wheel has been checked for clearance. Model Year 1991 on Brake Caliper Type CP5100 Brake Disc - Drilled CP4448-916/917RD, Ø285 x 25mm / 30 Vane Brake Disc - Grooved N/A Brake Disc - Plain N/A Brake Disc - Strap N/A Brake Pads CP2340D43-DS2500 Wheel 6.5J x 15" Speedline (212/P165 IIRC we got a print out of a template of the inner wheel then sent it to them to get them to spec Quote AP Racing have identified the actual size of the wheel necessary for a particular kit, and where possible have listed an example of an individual manufacturers specification, often other manufacturers wheels can be used, but inner wheel profile must be checked before fitment. It is usually the inner spoke area that causes the problem with fouling the outer face of the caliper.The following links to a number of wheel manufacturers may be useful. Compomotive | Revolution | Rimstock | TSW AP Racing does not recommend the use of a wheel spacer or removal of material from the caliper or wheel as a cure. We now have some of the most common Caliper Profile Drawings available to download, these can be accessed from the relevant brake kit via the Application Guide .If the relevant profile is not available online, please Contact Us as in many cases a full size profile drawing of the brake kit is available by post. hope this helps. Edited November 17, 2008 by kyepan Share this post Link to post Share on other sites
205wrc 16 Posted November 17, 2008 AP Calipers certainly do fit. These are CP2361 (also known as the AP Forest caliper). These are fitted on a 1.6 GTi disc and fit under a 14" wheel. These are the calipers that I use on my car. Combined with Ferodo DS3000 pads they are absolutely awesome. You can find them in the Demon Tweeks catalogue, page 310, priced at £352.50 each. They come as a blank, so that you can drill the mounting holes to suit your hub / disc size etc. Share this post Link to post Share on other sites
Guest rs-tone Posted November 17, 2008 5100 caliper is the one we fit on 106's under 15" rims Share this post Link to post Share on other sites
Spiky 37 Posted November 17, 2008 awesome can you send me a set, say 100 delivered?? ...pmsl Share this post Link to post Share on other sites
Guest rs-tone Posted November 17, 2008 With only 1.5" pistons they are not even worth that lol Share this post Link to post Share on other sites
Spiky 37 Posted November 17, 2008 rs-tone said: With only 1.5" pistons they are not even worth that lol ok i'll take my chances on them being crap for 100 quid when can i expect them...lol Share this post Link to post Share on other sites
Rippthrough 98 Posted November 18, 2008 rs-tone said: With only 1.5" pistons they are not even worth that lol Sold! Share this post Link to post Share on other sites
Spiky 37 Posted November 18, 2008 Rippthrough said: Sold! join the que Share this post Link to post Share on other sites
engine killer 6 Posted November 18, 2008 I guess apart from CP5100, you may also check out the CP3307, this is also running 285mm disc iirc. the 3307 doesn't need bracket for peugeot fitment neither. Share this post Link to post Share on other sites
