MrG
Rear Shocks
MrG
In all my old sockets & tools I can't find one that fits snuggly over the nuts that hold the upper bolt of the rear shocks on?
I want to remove them and no matter how hard I try I've either got one thats too small or slightly too big?
18mm both sides :)
MrG
thanks very muchly, I must have got to the end of my patience prior to those as I do have a set of metrics!!
It was either that or the cold and top gear took hold!
For some reason most sets have a 17mm and a 19mm but not an 18mm.
MrG
funnily enough I looked last and you're bang on!
so I'm off to rectify that tonight.
The bolts are also in a little recess and can be a right PITA! But usually do-able with a little perseverance!
MrG
thats what I found, didn't help not having the right size socket though!
Paintguy
I found out the hard way a few weeks ago.
I needed to change the rear dampers, so had a quick look under the car and guessed at 19mm. I went home armed with a wide variety of spanners and sockets in that size, only to find out they were to big :D
I had a go anyway, but after skinning my knuckles numerous times when the tools slipped, I decided to call it a day and had to wait until I could get back to work and get some 18mm stuff. It was a breeze of a job with the right sizes :)
